Thanks Tom for the reply.
Good steps to follow. See if I get this right (and from a different angle). If you could answer this at a deeper level, the user community could use this information. The GIS community is, for most of us, use to transformations, and, we understand that transforms, when applied correctly today, are 7 parameters, and when worked in forward or reverse directions, the math zero's out. But we would like to hear from the team what exactly is going on.
Assume for this example, i'm using NTRIP with NAD83 (2011) streaming incoming data, and my final output, I want in NAD83 (2011) for consumption in, say an ESRI world. Take us thru this will you?
From the Field to the Map.....
Assume I set properly the datum for NTRIP to NAD83(2011). TerraFlex, on the fly transforms the incoming positions to the Map Space in Terraflex,? or does it move the basemap to the assigned incoming datum.? The former shifts the data TO WGS84, the latter shifts the data FROM WGS84
Next, in Map Workspace, I am assuming the basemap remains always in WGS84. Is that correct?
If so, then from the field is workspace shifting the stored positions that are synced to WGS84 for display?
I am loosely referring to WGS84, which is not the correct datum (ITRF, IGS08), but for simplicity, this bear with that term.
thanks for your time.
