Brittany,
It looks like you are on the right path! The video that Frontier put together is the key to addressing the incompatible profile issue within Field Maps. Nearly every accurate correction source (VRS, RTX, etc.) are broadcasting corrections in NAD 83 2011 Epoch 2010. If you match the profile to what Karissa shows you in the video, you shouldn't be getting this error anymore. That is, of course, assuming that you are using AGOL versus Portal. If you are using portal and push out feature layers/web map in your own coordinate system, it's likely not Web Mercator Auxillary Sphere so you'll need to use your system (map coordinate system) in it's place. I hope this makes sense. Regarding your third R2 that seems to be behaving different that the rest, i would make sure it's on the latest firmware or at the very least that all three R2s match firmware versions.
https://forms.trimble.com/globalTRLTAB.aspx?nav=Collection-115212. Alternatively, it could be an issue with our RTK subscription on that unit so have you tried a different login to confirm? Also, there is a chance that your third R2 was not configured to be sub-foot (decimeter) so you can confirm this via the web ui (WIFI) or Trimble Installation Manager (via cabled connection to window matching running TIM).
Zach Edwards
Sent: 03-14-2022 11:21
Subject: Mobile Manager: Failed to connect to correction source
After lots of troubleshooting, I have a few answers, but not all.
Before I had posted this, I had done minimal research and mostly only had referred to the "Prepare for High-Accuracy Data Collection" page which did not yield very many results. I've done a lot more research and found a little more help on the issue, so I thought I would leave some helpful links in case anyone else has been having similar issues.
The biggest issue that we had in Trimble mobile manager was with the error "Failed to authorize connection to correction source. Please check username and password." I thought this was the source of the problem because if our units were not connecting to the correction source, then I assumed this would be the source of the problem in Field Maps.
This is not the case - I came to learn that users are meant to disconnect the Trimble unit in Mobile Manager before connecting the unit in Field Maps. We were getting this error because Field Maps was now connected directly to the correction source, so if we tried to connect the unit again in Mobile Manager, we would run into this error because the correction source login was already being used by Field Maps at this point. Both applications could not use our correction at the same time, so one app would have to be disconnected from the unit in order to view RTK corrections in one of the apps. The solution was to disconnect the Trimble unit and revert back to the integrated antenna in Field Maps, then connect the unit to view the RTK reporting in Mobile Manager and we had no issues after implementing this.
I have still been having issues with having an "Incompatible Location Profile" in Field Maps, but I suspect that I just need to find the correct transformation configuration from the R2 units in Mobile Manager to a custom location profile in Field Maps. Two of our Trimble units will allow us to close the error message and still submit points through the map interface, but the accuracy is still off. Our third unit will not allow us to submit points in the map at all, so I think something needs to be configured with the licensing for the third unit.
Here are a few links that helped me with some of the issues, and I will continue to update as I figure out what kind of transformation settings we need to use in order to be compatible with Field Maps.
On using the correct transformation with basemaps:
https://community.esri.com/t5/arcgis-collector-questions/z-coordinates-don-t-match-benchmarks/m-p/11741
https://community.esri.com/t5/arcgis-collector-questions/collector-location-profile-issue/m-p/90457
On setting up Trimble Mobile Manager with Field Maps:
https://support.frontierprecision.com/portal/en/kb/articles/setting-up-trimble-r1-r2-in-esri-field-maps
Brittany Betzer
