Hi Alexander
You cannot import shapefiles into an existing project unfortunately.
Importing
project source data (shapefiles as *.zip, DWG,DXF,CSV) needs to be done when you
create a project with the Penmap Project Manager
Once a project has been created you cannot add more source data to it
![](https://higherlogicdownload.s3.amazonaws.com/TRIMBLE/MessageImages/c9d03add06da4090866fb1c773aeda70.png)
A short work around for this If you have already created a project with data is to..
- Use the Penmap Project manager to export the existing project you wish to add this new source data to as type Penmap Project (*.pdt)
- Create a new project In the Penmap Project Manager
- For the Project Source data select the Penmap project file (*.pdt) AND the shapefile (as zip)
- This will create a new project with both the 'old' project data and the new shapefile source data you wished to import but could not due to the restrictions mentioned at the beginning
For more information on Penmap take a look at the
Penmap Community page and the
Penmap online help------------------------------
Tom Harrison
Sent: 10-04-2022 05:52
Subject: Import shapefiles in existing Penmap project
How do you import shapefiles into an existing Penmap project?
Is it possible to import shapefiles into a Penmap project after you created it using Penmap Project Manager?
Thank You
Alexander Doucet
Group Van Vooren nv
Penmap 1 Group Van Vooren
