Trimble Connect -  change attributes list
  • 1.  Trimble Connect -  change attributes list
    Posted 04-03-2019 12:37
    Is it any possibilities to change display of attributes sequence for object in Trimble Connect?
    I started use Trimble Connect for projects verification and I see one disadvantage comparing to TeklaBimSight. When I want to check object attributes, the most important information are at the bottom. I have to scroll down every time to check Product Description, Material  or top elevation of element.
    In this way I waste a lot of time.
    It would be perfectly if I could see at the first basic information about object and then secondary, less important information.
    Trimble-Attributes-list — imgbb.com
  • 2.  Re: Trimble Connect -  change attributes list
    Posted 04-08-2019 03:08
    Can you please let us know if you are looking for this in Trimble Connect Web or Mobile?
    Also can you please let us know the expectation - if this sequence can be set by each user for himself/herself?
    Darshan Kamat
  • 3.  Re: Trimble Connect -  change attributes list
    Posted 04-11-2019 12:44
    I'm looking for this in Trimble Connect App for desktop. Attributes sequence don't need to be set up by each user. It would be fine if it be set up for project only.
    Karol
  • 4.  Re: Trimble Connect -  change attributes list
    Posted 07-12-2019 01:24
    Hi
    I update topic.
    Is it possible to make function for sequences attributes list?
    Or other solution, for example tree view for attributes list. Then i could hide unimportant attributes and show only important information.
    Next idea. It would be perfect if i could choose information for displaying in bar properties (after right click). Now i can see only object name and top and bottom elevation. For lot of users, more important is to see information like material, product description or assembly mark. This solutions can make work with trimble connect really comfortable for lot of us.
  • 5.  Re: Trimble Connect -  change attributes list
    Posted 02-18-2020 06:20
    Hi.
    Any news on that yet? I have also been looking for a solution to this problem for a long time...
    Kind regards
    Pascal Russer
  • 6.  Re: Trimble Connect -  change attributes list
    Posted 02-19-2020 05:03
    Hello Pascal,
    We have a feature in the Trimble Connect for Mobile application that to me seems exactly what you describe. It's called the "Favorite Properties" and you can use it to mark your favorite properties with a star icon so that they show up in the top of the properties list. Please check the user guide for TC for Mobile: User Guide : Trimble Connect for Mobile - October 2019   to see how to view properties. You can then see the star icons next to each property and click those to make them favorite.
    For Trimble Connect 3D Viewer in the Browser we have the same feature request recorded in the road map (no specific availability date known yet, sorry).
    For Trimble Connect for Windows application this feature is not in the road map. This is will be evaluated separately.
    Please check the Connect for Mobile to see if the feature would meet your needs?
    Thanks and best regards,
    Jari
  • 7.  Re: Trimble Connect -  change attributes list
    Posted 02-19-2020 05:53
    Looks promising, i hope this also will be implemented in TC for Windows.
  • 8.  Re: Trimble Connect -  change attributes list
    Posted 02-19-2020 06:01
    Hi Jari
    Thanks for the quick response.
    Looks very good on the mobile version.
    I would be happy if this function will be available soon in TC Desktop.
    Kind regards
    Pascal
  • 9.  Re: Trimble Connect -  change attributes list
    Posted 09-30-2020 00:24
    Hello @Jari Juntunen,
    This feature is really great for TC for mobile and for the 3D viewer in browser, its actual so good, that i would think about
    change from TC for windows application to the use of 3D viewer in browser, just been able to see just the favorite attributes, our users only want the information they need in a neat way, and this does just that.
    I hope you will consider implementing this in the TS windows application as well, as this is the mainly way we use Trimble Connect, and it would help a lot.
  • 10.  Re: Trimble Connect -  change attributes list
    Posted 09-30-2020 09:01
    Hi Daniel,
    Like you mentioned, the favorite properties feature was released to the TC for Browser 3D Viewer in July. I'm glad you like it and I recommend it to all our users.
    Best regards,
    Jari
  • 11.  Re: Trimble Connect -  change attributes list
    Posted 09-30-2020 22:01
    Hi Jari.
    The favorite properties feature in TC web is very helpful.
    Is there a way to set these favorites for all project members, so that not everyone has to set these favorites individually?
    Best regards
    Pascal
  • 12.  Re: Trimble Connect -  change attributes list
    Posted 10-01-2020 00:22
    This would be helpful if this could be set for all project members and not individually!
  • 13.  Re: Trimble Connect -  change attributes list
    Posted 10-01-2020 23:32
    Hello Pascal,
    The Connect for Browser 3D viewer favorite properties are an user and project level preference meaning that they are saved for each user individually for each project. Currently there is no feature available to manage favorite properties centrally for all project members.
    Best regards,
    Jari
  • 14.  Re: Trimble Connect -  change attributes list
    Posted 03-27-2020 00:44
    Hi!
    I looking forward to this function in TC Desktop. How work progress looks? Can we expect "favourite properties" in TS Desktop soon?
