How to update/refresh Models in Trimble connect
  • 1.  How to update/refresh Models in Trimble connect
    Posted 10-31-2019 01:43
    How do i Update/refresh models in Trimble, for example i save my DWG in autocad, how do i update so I can se the changes in Trimble?
  • 2.  Re: How to update/refresh Models in Trimble connect
    Posted 11-13-2019 00:15
    I would also like to know how to do this. really hope that the team at Trimble is working on a simple solution to this.
    It was the best feature of Tekla and the only reason I used it earlier.
  • 3.  Re: How to update/refresh Models in Trimble connect
    Posted 11-13-2019 02:38
    I agree with above comment. This is an important feature of the software. Please solve this urgently.
  • 4.  Re: How to update/refresh Models in Trimble connect
    Posted 11-13-2019 08:30
    You can upload the DWG file again through the Trimble Connect Browser interface, or use the Sync Tool to regularly upload changed files from a specified local folder. In either case, Connect will keep the prior versions of your file and display the newest version by default.
  • 5.  Re: How to update/refresh Models in Trimble connect
    Posted 11-14-2019 00:32
      |   view attached
    Can this be done in the free version with  offline, unpublished projects?
    The TeklaBimsight automaticly detected when a file was updated (overwritten in server) and showed a clickabel reloadsymbol to update the BIM module.
    Mvh/
    Martin Wennbladh
    0707 – 87 60 28
    Från: ray_bagley@trimble.com <trimble@jiveon.com>
    Skickat: den 13 november 2019 16:31
    Till: Martin Wennbladh <martin@emwe.se>
    Ämne: Re:  - Re: How to update/refresh Models in Trimble connect
    Trimble <https://community.trimble.com/?et=watches.email.thread>
    reply from Ray Bagley<@Ray Bagley//community.trimble.com/people/ray_bagley@trimble.com?et=watches.email.thread> in Trimble Connect - View the full discussion<https://community.trimble.com/message/22552-re-how-to-updaterefresh-models-in-trimble-connect?commentID=22552&et=watches.email.thread#comment-22552>
