Which versions of SketchUp are compatible with Trimble Connect?
  • 1.  Which versions of SketchUp are compatible with Trimble Connect?
    Posted 06-04-2020 11:17
  • 2.  Re: Which versions of SketchUp are compatible with Trimble Connect?
    Posted 06-11-2020 12:28
    What do you mean by compatible?
    I believe that SketchUp Classic (desktop) has had a "Save to Connect" option since at least version 2018. SketchUp on the web is always integrated with Connect.
  • 3.  Re: Which versions of SketchUp are compatible with Trimble Connect?
    Posted 11-20-2020 12:28
      |   view attached
    SketchUp 2021 files fails to load and view in the viewer.
    Shared in TC
  • 4.  Re: Which versions of SketchUp are compatible with Trimble Connect?
    Posted 11-20-2020 12:51
    Hi Jack,
    Connect currently supports 2020 and below. The current workaround is down-save for now to 2020 ( File > Save As... ) and then upload directly from within Trimble Connect.
    Thanks
    Laura
  • 5.  Re: Which versions of SketchUp are compatible with Trimble Connect?
    Posted 11-20-2020 12:55
    You can find the latest supported file formats here: https://community.trimble.com/docs/DOC-9974-supported-files
