Tekla Weight of a selection
  • 1.  Tekla Weight of a selection
    Posted 09-01-2020 00:56
    I have imported a Tekla steel structure model.  The model is divided in phases. When I click at an object I can see the attributes as the Tekla Quantity (Weight).
    Is it possible to see the weight of a selection or predefined phase as a total?
  • 2.  Re: Tekla Weight of a selection
    Posted 09-09-2020 06:32
    Yes you can do it using the "Data Table" in the web version.
    It will allow you to sort and even color the selected elements according to the property you want (the phase).
    see this vidéo : https://youtu.be/3JwAq8fPbXs?t=467
    Regards.
    Alex
