GeoXT Accuracy
  • 1.  GeoXT Accuracy
    Posted 10-03-2020 10:38
    Hello Folks,
    I've just been given a GeoXT 2005 series receiver that was headed for the scrap heap as it was going to be "$12K to replace/recover".  With dealer help, I have upgraded the receiver firmware and Terrasync so that it is functioning and talking to an older version of PF Office for 0$.  All is well.
    BUT, points collected over known references seem to be displaced about 1.5 m to the WNW (SBAS RT correction).
    AND, my old ProXL, now upgraded to a ProXR, maps these same points almost exactly correctly using RTCM real time correction.
    I don't believe that it is a projection/datum problem or a hidden offset setting.
    Any thoughts on this problem?  Thanks very much . . . . .
  • 2.  Re: GeoXT Accuracy
    Posted 11-12-2020 21:23
    Unfortunately the Trimble Connect team will not be able to assist you with GeoXT related issues. The Geospatial forum is:
  • 3.  Re: GeoXT Accuracy
    Posted 11-19-2020 23:05
    OK, thanks very much . . . .
