Hi Joanna,
Thank you for your feedback.
I try to give you some answers:
1. Do you use orthographic projection? Please try with perspective projection that should have more stable camera position between platforms.
2. This is know issue that TC Web cannot load as big models as TC Desktop. We are working on this issue.
3. Could you save the event logs when such case happens that TC Desktop stops? Open Event viewer, browse to "Applications and Services Logs / Trimble". Then right click on the Trimble and save all events to a file. Then please send that file to marko.myllymaa -at- trimble.com. (Fix the email address first.)
4. Email notifications are sent in certain interval, if sending event was just passed, then notification are pushed to next sending event. Making this more frequent will cause much traffic to our server. We will investigate this, if this could be improved.
Best regards,
Marko Myllymaa
