I recently found myself in front of a problem with the trimble sync manager. Apparently due to some wrong characters, some files are not able to be synchronized. I don't know if it's a special character which cause this problem or something else. Nevertheless as you will see in the attachment some can sycnhronize et some cannot.
We are currently using, the 2.47.8.0 version, which, until this, was working perfectly fine. The lastest one has other problems such as putting files in others documents.....
Best Regards
Florent
