Wrong display of construction in TC web
  • 1.  Wrong display of construction in TC web
    Posted 07-11-2018 07:07
    Hi all,
    I would like to report the following problem with construction display in Trimble Connect web. Fo further details please have a look at picture 02.png. The problem is caused by large coordinates. The display is not ok, even if I use Positioning funkcion. The only possible way how to solve it is to change the position of the construction in the original file, which is not always possible.
    thx
    Pavel
  • 2.  Re: Wrong display of construction in TC web
    Posted 07-25-2018 05:34
    Hi Pavel,
    Thank you for reporting this. We are working to fix this issue.
    If you need to work with such models, please try Trimble Connect Desktop. Large coordinates should work there.
    Best regards,
      Marko Myllymaa
  • 3.  Re: Wrong display of construction in TC web
    Posted 07-26-2018 01:08
    I'm having the same issue on iPads/iPhone with Trimble Connect app.
    Models with large coordinates messes up the view, but if model is moved to (0;0;0) there is no problem.
    Img 1: Large coordinates
    Img 2: Coordinates moved to (0;0;0):
  • 4.  Re: Wrong display of construction in TC web
    Posted 12-19-2018 04:54
    Is there any news or time horizon to a possible fix to this issue?
  • 5.  Re: Wrong display of construction in TC web
    Posted 12-19-2018 05:08
    We recognize this is an important item to be fixed. There is some improvement now with 2.6 - with respect to measurement precision. We will keep you posted on the latest updates.
    Darshan
