Thanks Raghav,
The problem with uploading the comments as a separate drawing is that when you search for a drawing, several versions of the same drawing will appear and cause confusion over which is the latest drawing.
There will also be situations where multiple comments are received from different parties, potentially leading to multiple copies of the same drawings, with no explanation or confirmation as to which one to work from.
Regards,
Steve Chudley
Design Management & BIM lead
Mid Consulting and Contracting Ltd
Suite 31,
BEC2,
50 Wakering Road,
Barking
IG11 8GN
