For Trimble Connect Web, I tested clash detection but it still processing I didn't get any clash result, see attached screenshot, hope someone can help me to solve this problem.
I'm having the same issue with the desktop version of Trimble Connect. Have you found any cause / solution / workaround to that?
now I haven't found any solution to solve this problem. but for clashes, I always use navisworks to do clash and clash management.
The same for me. the status bar is gray and says 0%. nothing happens
I´m on the desktop version btw
Good evening,
I've been having the same issue with clash detection. Is their a solution for this? Thank you.
Best regards,
same problem here, is there any solution to fix it?
