The first time I did this, it's good, then when creating new .vce files- I noticed that my cal file has topo measured points aside from my control points. Is there a bug on BCE software and why is this happening? Is there a way to eliminate the CAL file from happening like this? I attached the pdf showing on left is my original .vce file with NO topo points on CAL file, and on the right is the new .vce file where the same CAL file is used but has also topo points.
Appreciate any input on this matter.
Thank you.
