Hi Kjell,
Yes, it seems that you have issues in import plugin installations. I could open the models without problems.
Please open regedit.exe and check following path:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Tekla Corporation\Model Sharing Foundation\plugins
Check the plugins listed there. There should be each plugin listed only once. If there are multiple versions of the same plugin, then you have the issue and following the next steps will fix that.
- Uninstall Trimble Connect Desktop (And Tekla BIMsight if you have that)
- Uninstall all plugins, check "Programs and Features" or "Add or Remove Programs", and plugins start either "Trimble Solutions ImportSDK" or "Tekla Model Sharing Foundation" Uninstall all of them one by one.
- In Windows Explorer clear these folders:
C:\Program Files\Trimble Solutions\ImportSDK
C:\Program Files (x86)\Tekla\Model Sharing Foundation
-In regedit.exe, remove all remaining import plugins listed here:
Now you should have cleared you computer, now you can install Trimble Connect Desktop.
Note! If you need to use Tekla BIMsight also, that needs to be installed first.
Both software is using same import plugins. Trimble Connect Desktop has newer versions, so it should be installed last.
Hopefully this helps.
Best regards,
Marko Myllymaa
