Unit failure in Trimble Connect Web
  • 1.  Unit failure in Trimble Connect Web
    Posted 11-06-2018 01:45
      |   view attached
    I have my settings on Kilograms. However the weight in Trimble Connect Web viewer is displayed in pounds see prove below.
    Please fix the unit settings…We are making a tool via the API and Trimble Web Viewer which uses the weight. However it does not give the correct value.
    Attachment(s)
  • 2.  Re: Unit failure in Trimble Connect Web
    Posted 11-06-2018 16:35
    Thank you for reporting this issue. I have created a support case for you to track and will keep you posted once the issue is resolved. Please let us know if you have any other feedback.
