  • 1.  Problem with crashes
    Posted 12-02-2019 02:49
      |   view attached
    I am running a test run with trimble connect with a free license. I have introduced two IFC files to perform a collision detection test. The interactions appear in red and only with a percentage of 1% tested. What is the normal duration? It is a very small work but I do not see the percentage progress. Thank you
