Hi Johann,
You can try the following steps -
1. After the files upload has started, navigate back - out of the folder.
2. Use the Edit option (pencil icon) against the folder name. You will be able to edit the folder name.
Darshan Rajaram Kamat
Sent: 05-11-2022 01:48
Subject: Upload progress overlaps "save button"
I'm adding documents into folders but when I try to edit a folder name at the same time the "save button" on the bottom right of the screen is hitten behind the upload progress window, which I cannot move away from the save button. Therefor I cannot edit folder names while uploading documents.
Is there any way to fix this?
Jóhann Ingi Jóhannsson
