ELI5- Importing Points: No point file format match found in Civil3D
  • 1.  ELI5- Importing Points: No point file format match found in Civil3D
    Posted 09-28-2021 13:02
    Edited by NATE HOBBS 09-28-2021 13:22
    New at this, but I'm attempting to import my first set of points from my new equipment (Terraflex/Nomad 5/R2) to Civil3D. When I try to import the .csv from Trimble Connect I get "No point file format match found". Is the problem the relationship difference between PENZD and PNEZD? Thanks for your expertise.
    EDIT: Update...a few minutes later...I was able to bring the points in after deleting letters associated with points and the headings for each data point. I guess this is what I'll have to do post-processing?
    Thank you,
    Nate
    NATE HOBBS
