I have imported a P6 XML into TILOS. I did NOT select "IMPORT LINKS" from the wizard, but the links are coming through and more importantly and annoying is that there are Red Arrows showing the links. Is there a way to toggle those off? Truly awful....
I didn't realize that the links were automatically imported. I usually always want the logic to come with the tasks. Turning off these annoying red lines (links) is easy. Simply click on the background of your time-distance chart and un-check the display links option as below.
Thank you very much Lorne!
Thanks for your quick response, Lorne. We couldn't have said it better.
David
By the way Andre, just to add to Lorne's response. If you are concerned that the links are displaying as RED arrows, you can change this. In TILOS Explorer, go to Library | Other Libraries | Link Categories.
Thank you Dave.
