version:10.3
description:
There are 4 tasks in the project. I want to show the progresses with WPA function for each task. when the "show to date" sets in first task time range, every things looks fine. But when set the date to second task time range, the first task progress bar get longer then before. The progress bar get longer with the time seted beyond task time range. So does the other tasks.
What's more, when resize the cell. The graphic will change more ridiculous.
Is any thing I forgot to set?
There are the fully operation contents GIF and video in the attach. You'll find more then I descripted. They shows same thing in different format.
