Trimble Penmap
Error message when importing dwg file to Penmap Project Manager
  • 1.  Error message when importing dwg file to Penmap Project Manager
    Posted 02-17-2022 03:10
    My company owns a landfill and we are looking for a easy method to monitor the heights as the landfill fills up.
    We have a DWG file which shows the correct height.
    We  have bought Trimble Catalyst DA1 and Penmap Project Manager and I hope to use this setup to see the difference up to final height when I am standing on the landfill.
    But I am struggeling import the dwg file to Penmap. I get an error message saying "Conversion of dxf/dwg went wrong."
    Any idea what I can try to get past this problem?
    SHMIL IKS
  • 2.  RE: Error message when importing dwg file to Penmap Project Manager
    Posted 02-17-2022 05:54
    Edited by Markus Koper 02-17-2022 06:17
    Dear Shmil,
    Are you in contact with your local Trimble distributor and have you already described your workflow to them?
    It would certainly be good if you shared your DXF/DWG file with them and also tell them what coordinate system you would like to work in and what system your DXF/DWG was created in.
    Markus
    Markus Koper
