We have released a new Penmap for Windows version.
The version 11.4.0.8735 includes the following enhancements:
New features
New Photo Wizard
The new integrated Photo Wizard is a tool to add information to photos and create sketches. Any photo captured as a GIS feature using Penmap can be edited using the Photo Wizard. You can also create sketches that do not have a background image, to better illustrate complex issues. Use the Photo Wizard to:
sketch on a photo (mark areas, set arrows, type notes)
save sketches
load existing pictures and add information to them
It is now possible to load and save a calc file (site calibration) to a specific folder.
Enhancements
Change SAPOS-Ntrip Caster to URL addresses to avoid conflicts with outaged IP-addresses.
Fixes an issue where the Side Menu was not cleared for a new project.
Fixes an issue where a project references to the wrong coordinate system library after a crash. When opening a project after a crash the message "project uses old coordinate system library" appeared.
Update Coordinate System Database to DB95.
Penmap no longer closes if the Bluetooth NMEA connection is lost.
UNV Export no longer needs to export GIS photos into the UNV export folder.
Minor bugfixes.
Cornelia Schmitz
