Hello Jay,
thanks for the feedback. We will create some content to clarify the workflows.
Currently we have two support bulletins which are in conjunction to the iFeature:
Share templateCreate template from existingIn general the rough steps to create and synchronize templates are
- a template is set up/edited in Penmap Project Manager and therefore stored in Trimble Connect
- the template is immediately available to create new projects in Penmap Project Manager
- the template can be downloaded to Penmap for Android if a project with the template opens
- the template can be downloaded independently in Penmap for Android in the main menu (three bars in the upper right corner) | Download templates
- the template is stored inside the project. An existing project is not affected by template changes via Penmap Project Manager.
- if the template is edited in Penmap Project Manager and shall be used in Penmap for Android it needs to be downloaded via the main menu
If the template is not available you can do the following steps
- log in to Trimble Connect (
Trimble Connect) and check if the template is available in the Penmap templates folder
- Clean up the Penmap Cache (main menu (three bars in the upper right corner) | System | Clean up Cache) and try again
Hope this helps a little.
If there is a special workflow you have in mind please let us know, then we can add it to the upcoming documentation.
Kind regards
Conny
Cornelia Schmitz
