Search Options
Topic Thread
Trimble Penmap
Community Navigator
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
CSV expoort
1.
CSV expoort
1
Recommend
Stange Energi AUS AS Stange Energi AUS AS
Posted 04-22-2021 13:14
Reply
Options Dropdown
Hi
Any tips on why the CSV export in the Code column gives me the point type ex SmallCross in stead of the Code?
2.
RE: CSV expoort
Recommend
Patrik Stahlhut
Posted 04-23-2021 07:19
Reply
Options Dropdown
Dear
Stange Energi AUS AS,
we are aware of this issue and are working on a fix for the next release-version.
This seems to be a template update issue from Penmap version 10 to Penmap version 11.
You could either keep on working in version 10 in the meantime, edit the template yourself to use it in version 11 or request a support ticket via your Trimble dealer if you need help with this process.
Kind regards
Patrik
Penmap support
Patrik Stahlhut
Original Message
Sent: 04-22-2021 13:13
Subject: CSV expoort
Hi
3.
RE: CSV expoort
Recommend
Thomas Schucker
Posted 04-27-2021 04:50
Reply
Options Dropdown
Dear
the issue should be fixed with the latest release which we have rolled out today on Google Play Store.
Unfortunately the fix works only for new generated projects.
Penmap is not able to repair the Code value on already collected features in existing projects.
If you still see the issue with the new version and new generated projects, please let us know.
Best Regards
Thomas
Thomas Schucker
Original Message
Hi
New Best Answer
Copyright 2021. All rights reserved.
