We have numerous Trimble Penmap apps and DA1 Antennas in use across Australia. In the last two weeks we have no connection service multiple times and over extended periods. Is anyone else experieincing similar issues.
We use centimeter accuracy on demand hours. When accessing the GNSS network through Penmap it will struggle to get a accuracy below 0.2m - 0.3m. This is on the same locations two weeks previous we have accurate lock immediately.
The service will also jump from numerous to zero satellites.
The number of satellites icon changes to blue. We have no idea what this means.
Diagnostic log files have been sent via the Penmap application but Trimble bounces them back and requests you to contact your supplier. Not much point having the function if you are sending files back.
I have contacted our Supplier and they are in communication with Trimble, however they seem to expereince the same service that we experienced, very little
Extremely frustrating for our Techs in the field and our Customers.
TAP Admin Maxam
