Hi Jakub
I don't believe what you are asking for would work as you expect, and it would not solve the problem you have described..
The way GPS / GNSS signal repeaters work is that any GNSS receivers which receive the repeated signal will report the same position as the original GNSS antenna. In the situation you describe, all the receivers in the valley would report the position of the GNSS antenna at the top of the slope. Or more likely, the GNSS receivers in the valley would receive some real GNSS signals from satellites which are in view, as well as some repeated signals which would not correspond with the real signals so the GNSS might not give any position at all.
The only practical use I know for GNSS signals repeaters is where you want to check that GNSS equipment is working, in a location which does not have a good GNSS signal, for example, in a repair facility inside a building. When used like that, all GNSS receivers in the building will report the position of the GNSS antenna - but that doesn't matter because all you are trying to do is check that the GNSS receiver gives a position. And note that if you move around inside the building where you are receiving the repeated signal, the reported position will not change.
As a final point, GNSS repeaters are restricted or illegal in many countries, and they can interfere with normal operation of GNSS receivers.
Norman Smart
Sent: 03-12-2022 01:33
Subject: Trimble Catalyst as signal transmitter to another Trimble
Hi Everyone, I have pretty unusual issue. At our site we have very poor satellite signal mainly because we operate in between two pretty high slopes. I was wondering if Trimble Catalyst may serve as signal transmitter to another Trimble. If yes, we could buy one more, buy subscription, install it on the top of the slope so this second Trimble could give signal to the Trimble we would use to locate given GPS points.
What do you think? Many thanks, Jakub
Jakub Rudnicki
