Hi
I´m having trouble with the accuracy of my Sitevision unit out on site – I'm working in Denmark.
When I tap the GNSS Status icon the position status height is around 100m, when compared to our other Trimble survey equipment it should be more like 15m. Is there anything I can do to reset or adjust?
I´ve checked that we're using the correct coordinate system, I haven't adjusted the GNSS Minimum High Accuracy so it's still at 5cm. And this is whilst there is a decent connection i.e. icon is green with over 15 satellites.
Peter Otiv
