I have tried to use my client's iPad Pro 11" (2nd Generation) with iOS: 14.8, with Trimble Mobile Manager version2.8.1.1050 & ESRI Field Maps version: 21.3.0 (Build 512).
However, even we have reached RTK Fixed in TMM, going back to Field Maps still got accuracy of around 1m, and Fix mode is differential or even autonomous. We have tried with another iPad with IOS 14.6, and it works perfectly. The version of TMM &Field maps on the both iPAD were the same. The testing were done in the same place at similar time.
The only different should be the IOS, iPAD version and log in account of ArcGIS.
Not sure about the reason, Did anyone has got the same problem?
Thank you.
Vivian Lee
