Catalyst Accuracy in Peru
  • 1.  Catalyst Accuracy in Peru
    Posted 05-04-2022 10:46
    Does anyone have any insights as to how accurate Catalyst can be in Peru?  RTXAL (Latin America) is available in Peru. I have a Catalyst kit (DA2 antenna and a TDC600) and will be mapping in a remote area in highland Peru that does not have internet service. Internet is available in the nearby town.
     I would like to use the highest accuracy subscription possible (Catalyst 1cm) for mapping in Peru, but I realize this may not be possible, since Peru is neither in a VRS now region nor is it in an RTX fast region. Is it fair to assume that 1cm accuracy is not possible? With Trimble Corrections Hub in a remote area with no internet service, what accuracy can I reasonably assume I can get?
    In 2016, I used an R2 and Centerpoint RTX to take points at 4cm accuracy. Is this not possible with Catalyst?
    Any insights would be greatly appreciated. Thank you!
    -Jacob
    Jacob Bongers
  • 2.  RE: Catalyst Accuracy in Peru
    Posted 05-04-2022 21:54
    Hi Jacob,
    You should get accuracy at least as good as your previous experience with the R2 using RTX. As long as you are able to download sign-in and your Catalyst license while online you are then able to use Trimble Catalyst offline for up to 30 days at a time. You can see the Catalyst DA2 Web page on Trimble.com here, I would especially recommend you look at the FAQ.
    Best regards,
    Mark Kellaway
