the behavior you see here is correct.
The 'don't use TMM' feature is called off-the-shelf licensing in the TPSDK documentation.
It allows to bypass TMM and gives access to features of a traditional GNSS receiver like a Trimble R2 or Trimble R10 etc.
Applications don't have this on default; if we would add this feature to the facade it would allow reusing this GUID.
So in order to test this you need to register to the SDK and start the partner process; in this process Trimble creates a product based on your specification (app name, package name etc); in this process we also provide a product specific GUID which can be enabled for off-the-shelf (if requested).
Hope this makes sense.
Nico
Nico Becke
Sent: 01-25-2021 04:49
Subject: Unable to load driver without TMM
I got "ErrorLoadingDriver" error after click load subscription with "Use Trimble Mobile Manager" disable in settings. When I load Subscription use Trimble mobile manager it works fine.
Am I missing something?
ferap wew
