Reports
04-16-2021 08:38
Reports
Use this function to generate reports for the current Water and Sewer project.
  • The following types of reports can be generated:
  • Coordinates for manholes clusters
  • Coordinates for sections
  • Quantity reports for pipes (sorted by type)
  • Quantity reports for pipes (sorted by sections)
  • Quantity reports for manholes
  • Trench table
  • Volumetric Calculations
  • The reports generated can be viewed in Rich Text Format (RTF).
  • The generated reports can be exported to any of the following formats:
  • Microsoft Excel Worksheet (XLS)
  • Portable Document Format (PDF)
  • HTML
  • Rich Text Format (RTF)
  • Text (Notepad)
  • Tagged Image File Format (TIFF)
  • The title for the report being generated and desired logo can be defined in the setting.
The minimum requirements before executing the function are as follows:
  • Complete the design process of the Water and Sewer project.
  • Run the calculations for cross-sections and quantities. Refer to the topic 'Calculations' to perform calculations.
The dialogue box Novapoint WS Reports will pop up.
Reports
  • To generate a report, select the report from the Report List and click the button Generate Report.
  • The report generated can be viewed in the rich text format (RTF).
  • E.g.: Report generated for Trench details with a logo.
  • To export a report, select the report details from the Report List, click the button Generate Report to generate the report, and then click the button Export.
  • The dialog box Export will pop up.
  • Select the format to which the report generated is to be exported from the drop-down menu at Format.
  • Define the path for the file, other general settings and click the button OK.
Setup
The logo and the title are defined on the tab Setup of the dialogue box.
  • Define the name for the report to be generated in the field “Title”.
  • Select the logo to be inserted on the reports using the ellipse button next to the field “Logo”.
  • Define the path and name of the “Bitmap file” in the field “Logo”.
  • The selected logo will be displayed when the button Show Logo is clicked.
  • Finish: Use this button to exit the function.
