Select class code file
08-11-2021 04:46
What
This function makes it possible to associate a class code file to the task.
Where
How
The following method is used:
  1. Download the Csv-file and save it to custom folder
  2. Select the WS-task where the class code file is to be used
  3. Start the function and select the class code file
  4. Click Open
  5. Open layers and check if it worked on all pipes and manholes
