View Entry
Back to Library
How to draw 3D-solids with stakeout data
Recommend
08-12-2021 06:53
Eirik Braaten
Problem
This is a step-by-step solution to draw 3D-solids and stakeout data.
Solution
Draw 3D solids
Open a new drawing with the correct template
Click on
Show 3D Model
Select relevant trenches
A dialogue will appear. Edit in configuration to add parameters to layer and text
Click
Create 3D
Double click on the scroll wheel to see the model
Stakeout lines
Click on
Draw 3D pipes/ manholes 3D from WS model
Select the correct parameters and reference points and lines
Finish with
Draw
Stakeout data can be retrieved from
Setting out
in the Novapoint ribbon
Click
Select object
and select the line that represent the trench bottom
Press
Enter
. Observe the table
Click
Draw table
and select placement in the model space. Placement will be the upper left corner
