Great news Trent, thanks for the follow up
I was going to suggest 'turning it off/on again' but I didn't want the abuse :-)
Glad you're all working
Tom Harrison
Sent: 10-12-2023 07:38
Subject: Accuracy of Catalyst 30 using Propeller App
When I went back and tested with the new Frame and Geoid settings it was even further off.
I decided to delete and reinstall both Mobile manager and the Propeller mobile. Once this was done and settings were completed again it was working perfectly!
Thank you very much for the assistance!
Trent Walters
Sent: 10-10-2023 08:04
@Tom thank you very much for the suggestions.
- Yes, TMM is set to be the mock location provider
- The detection mode was set to auto and the Geoid was set to EGM96 (Global)
Attached is the processing report from propeller. Based on this the Frame has been updated to NAD83(2011) (EPOCH:2010) and the Geoid to Geoid12B (Conus) as shown in the attached image.
Does it matter if NAD83(2011) (EPOCH:2010) is used versus NAD83(2011) (EPOCH:2017.5)
I will be testing this out later this morning on site.
Trent Walters
Sent: 10-10-2023 03:01
Hi Trent
Two things to check here
- Have you set TMM to be the mock location provider? Take a look at the Location Sharing with other apps section of the help
- Is this a datum Issue? Make sure your GNSS Output datum matches the reference frame your Propeller app is using
- For example - If it's using WGS84 then you can select that output option from the list of TMM reference datums so they match.
- If they don't match then you will have a positional error based on the difference between these two systems.
- For more Information on this topic and practical advice take a look at the BLOG: Common Problems With Coordinate System Configurations
It might be a good idea to reach out to your local Trimble reseller at this point. They will have specialist local knowledge to help you determine and resolve this issue
Tom Harrison
