Add "Model" as default to datatable data fields
  • 1.  Add "Model" as default to datatable data fields
    Posted 07-19-2023 07:58
    This is a suggestion that I'm hoping can be easily implemented and can make a substantial difference to user experience. Currently the datatable on TCW adds a new data field named "Model" every time more than 1 model is toggled on in the 3D view, and the values of this property are the model filename. However, if only one model is toggled in, this atribute no longer appears on the list. This causes issues, for example, if a data preset is deployed that can be used for either one model or several models, as this will result in different data structures to the datatable and exported csv files, and that can hinder follow on workflows like reporting automation.
    Would it be possible to have the "Model" atribute always available on the list of properties of the datatable, regardless of the number of models selected in the view?
    Regards,
    Ivo Garcia
