Considering not all building is 90 degreew or 180 degrees to the 0,0,0, so you cannot use the standard views(Top,Front,Left,Right) Is there anyway we can set the view to be perpendicular to the section cut created?
The photo attached as an example. This project is 45 degree and none of the standard view would work (Except top and bottom, of course!)
Pia Nithi
