Thank you Zach. I did not recall seeing the multiple options within Terraflex until recently and the Trimble Terraflex Help Portal does not have any information about these settings. So after this post, I learned that Trimble makes a different insert for the DA2 which is 0.026 meters longer than the standard one that comes with the packout. So I assume the Pole Cap Long setting is for that particular accessory.
Trimble Antenna.ini Antenna Viewer (trimbletools.com)
Daniel Bollich
Sent: 08-25-2023 07:11
Subject: Antenna Height Method Setting in Terraflex for Catalyst DA2
Daniel, I am 99% sure that you want bottom of antenna mount.
Zach Edwards
