Just tried again. One thing I did not do origanally was not adding all the image file into the Background Image folder. That was KEY!! thank you Shea.
Sent: 07-17-2024 08:27
Subject: Background Images for Siteworks
Does the background image load?
Sent: 7/17/2024 11:24:00 AM
Subject: RE: Background Images for Siteworks
I will have to try again and write down what the error message says. My project is calibrated and have open the PDF in GE. Which have been placed correctly in GE.
Francisco Guerrero
Sent: 07-17-2024 08:17
Site has to be calibrated. Or in State Plane.
Shea Huckaby
Sent: 07-12-2024 18:35
i had thought once it is captured. it will be correctly placed in the project inside Sitework. i get the error message in Siteworks, say to georeference the image.
Francisco Guerrero
Sent: 07-12-2024 07:42
@francisco where was that error in TBC or Siteworks? From the Siteworks side all you really need is an image, then you can import the image into Siteworks and perform a 2 point georeferencing of the image right in Siteworks. From TBC, I was just able in 2024 to open a new blank project, I dragged in a random VCL design file, and then simply hit the "Capture" button in the Images submenu of the CAD tab in the ribbon. My project didn't have a coordinate system per se and the image was produced.
If anyone is having issues producing the images, then I would encourage you to work with your SITECH dealers to submit a support case to Trimble. Provide them sample VCE project files and folders, and tell them your workflow. Generally, while the threads are a nice way to report in issues, we are limited in our abilities to actually look at anythign unless it comes in as a support case via your reseller (be that SITECH or Geo). So get the data to your dealer with your bugs and then they will send it on to Trimble.
Steve DiBenedetto
Sent: 07-11-2024 17:17
i just recently tried doing the capture image to import into Siteworks. I kept getting an error message saying no geo location. what is needed to import an image into Siteworks?
Francisco Guerrero
Sent: 07-10-2024 07:50
Ben,
I have also encountered this problem since around version 5.9. I am unable to generate any background images, plotbox or screen capture, regardless of size. I suspect that it is a bug, which is unfortunate. I am currently running Version 2024.
Alejandro Banuelos
