Hello all,
Working in the central PA yesterday (05/13), we had one of two DA-2 units lose satellite coverage midday, drop the connection and then refuse to pair with the iOs 15 phone. I worked with the tech after hours and saw no resolution. This morning I unwrapped a shiny new DA-2 for the field team. Of course, the problem child from yesterday seems to be working fine now. I thought it was either the field tech or the unit, but maybe, it was something in the system supporting Pennsylvania.
Chris Abbott
Sent: 05-13-2025 14:08
Subject: Cannot Connect to Trimble DA2
Hi Mary,
It may be that the pairing between the DA2 and the iPad has become corrupted in some way. I would reset the DA2 (10 second press on the button until you see from the LED that it is reset), then go to your iPad Bluetooth settings, find the entry for the DA2 and forget it. You should then be able to re-pair.
Regards,
Mark Kellaway
