Hi David
First thing to check Is that you are using the latest Catalyst service for the DA1 - If you take a look at the DA1 releases page the latest Catalyst service version is 1.5.2385 (released September, 2022)
- If you connect to the DA1 using Trimble Mobile Manager you can get this version information under the Position source screen
- This will also tell you if the service version is up to date or requires an update via the UPDATE option - help reference
Secondly, what is your current location (country/state level will do) and are you working online or offline? These factors all determine what type of service and performance we can expect with the DA1 and will help us give a more detailed picture
If need be we can create a support case with one of the team and take a look at the logs
Tom Harrison
