Thanks Peter. I got your last email reply in our CRM (Salesforce).
Think the issue was the large file size of your model. Unfortunately Salesforce rejects emails with large attachments and doesn't notify the sender or us sadly.
I expect you are good to go with the JXL and the Geoid now. Let me know if there's any future issues though.
Brendon Edge
Geospatial Support Manager
Trimble New Zealand
Sent: 03-03-2021 01:43
Subject: Catalyst with Sitevision - height problem
Hi Brendon I've replied to your email but if it doesn't get through to you here it is again:
Hi Brendon,
Thanks for your reply. I think you're right, everything seems to be set up as it should be. That's good to know.
It's a bit tricky for me to double check because the building site is far from my own location and the guys on site don't have time to investigate in so much detail. Next time I'm out there I'll make the checks you've suggested here and get back to you but there could go a couple of months before that happens.
Thanks for the help, hopefully the problem has resolved itself
Peter Otiv
Sent: 02-24-2021 01:16
Hi Brendon
I replied to your message directly in the email so I guess it didn't get through to you, hope you see this one.
I've uploaded one of the model files (dgn) we're using plus the jxl file that I made in Business Centre and log file from Sitevision.
We're working near to Skjern, Denmark so I believe the coordinate system should be KP2000J with geoid DVR90
best regards
Peter Otiv
Peter Otiv
Sent: 12-20-2020 13:47
Hi Peter,
I found your Support request and will answer your question from there.
I expect this will be related to the Geoid in use by your model, or the fact that without a model you will be using a Global Geoid (EGM96). But it may take some back and forth to identify and resolve this.
Brendon Edge
Trimble New Zealand
