Thanks Vijay.... and BTW, if it's not on the radar (I've got a couple support cases on it) PLEASE change the behavior of deleting the old designs first before replacing with new designs v.02>> etc. on machines in WM..... when we get slow downs and hiccups in the design publishing this is killing our customers in the field, because they are left without a design to work off when they're waiting for WM to finally get the publishing done!.
Delton Searles
Sent: 11-05-2025 02:29
Subject: changes made to IBSS
Hello Delton, thank you for your feedback, and regret inconvenience. We will brainstorm internally to figure out how to solve 'one to many ibss sharing' use case in v2. In the interim, please note that the v2 transition is done only for customers that don't do sharing today.
Vijay Raghunathan
Sent: 10-30-2025 08:17
I'm not sure it's related to Ben's question, but your statement is related to MY question and concern, YES! IBSS v2 elimination of one to many device sharing for complex customer arrangements is a HUGE issue, when and IF you guys ever figure it out and actually implement it.... the general relay of OLD outdated documents, the ethereal promise of "you can do that with conventional NTRIP" connections through IBSS, and the lack of detailed documentation on exact syntaxes, etc. etc. are ALL concerning things with IBSS v2 rollout.
Delton Searles
Sent: 10-29-2025 13:29
Is this related to the changes in sharing, which does have reduced functionality, or something else?
Geoffrey Kirk
