changing scale
  • 1.  changing scale
    Posted 11-01-2020 15:40
    can you change the scale on a file that your importing
  • 2.  Re: changing scale
    Posted 11-03-2020 00:49
    You can change the scale of a file in the 3D viewer.
    To do this, select the file \ Position settings \ Scale
    Alex
  • 3.  RE: Re: changing scale
    Posted 08-28-2025 05:21
    I have a project with tons of DWGs and tons of xrefs, which are in metric scale, but models are in milimeters. Is there a way to do bulk scaling for all DWG?
    Andris Ablaževičs
  • 4.  RE: Re: changing scale
    Posted 05-28-2026 09:57
    The scale settings in Trimble can be easy to overlook, especially when switching between layouts or imported files. This should definitely help anyone running into the same issue.
    Briella Carson
