Quote
This may be a silly question, but if I ran both the sonar GPS and the Trimble DA2 simultaneously (and if both record timestamps with each position reading), could I simply replace the GPS position readings with the GNSS readings based on shared timestamps?
I don't see why this wouldn't work - certainly it's cheaper than buying a Trimble Access license. Since your sonar has a GPS it should give reliable GNSS time stamps which should match the DA2 time stamps (although those may be in UTM or in the local time zone so you'd need to take that into account including the 18 GPS Leap Seconds.) Without thinking too deeply, I'd say you need DA2 with subscription for whatever accuracy level you want plus TMM on Android to control DA2 and supply corrections and some app (not necessarily a paid app since you don't want to do much with it) which records the position in Android on a second-by-second basis. iPhone might also do it but I avoid those personally.
Norman Smart
Sent: 11-10-2024 12:28
Subject: Connecting Trimble DA2 (with Catalyst 30 and TDC600) to boat-based sonar
Thanks for the response, Zach! I'll look into this strategy.
This may be a silly question, but if I ran both the sonar GPS and the Trimble DA2 simultaneously (and if both record timestamps with each position reading), could I simply replace the GPS position readings with the GNSS readings based on shared timestamps? I'm guessing not, but just trying to explore all of my options.
Some Trimble dealers seem to think I could accomplish my task using Trimble Access, but since my use case sits between GIS and survey specialties (and is unusual for these types of devices), no one seems to know for sure.
Thanks again for the insight. I'll continue exploring.
Bryan Bozeman
Sent: 11-09-2024 10:00
Bryan,
The Catalyst DA2 system does not support NMEA out. It's a pay to play system that's super convenient but does not support NMEA out or static logging. Ideally, you would have your sonar system stream readings out via bluetooth to an android device (and associated app) and then the GNSS from the DA2 streams to the android device via bluetooth with Trimble Mobile Manager running with mock locations enabled. I don't believe that you can do it the other way around unless your sonar has their own android app that support GNSS via android location services. If you truly need NMEA out, you would want to look into a Trimble R2 or R580 using VRS or RTX corrections.
Zach Edwards
