Hi Howard,
The first post in the thread above is from 2020.
If you are facing any issue on Connect Sync now, firstly sorry to hear that. Please report it through our Support channel as mentioned above alongwith the application logs.
Since Connect Sync is a desktop based application, the reason for crash can be determined only after investigation.
Darshan Rajaram Kamat
Sent: 01-26-2023 10:13
Subject: Re: Connection problems
Darshan
Several of us have this problem, it would not be a better use of your time if you could give the solution by this medium or forum?
Howard Flores
Sent: 06-11-2020 21:48
Hi Mirko,
Could you please get in touch with our Support team (connect-support@trimble.com) so that we can find the root cause and get this resolved for you.
Darshan Kamat
