@Zach Edwards - are you meaning the user is being logged out of ArcGIS Online in Field Maps because he opened TMM then opened Field Maps (when not needing to because the TMM configuration had already been completed)?
I did not see Step 2 (from your first post on 6-14-25) on the Get Started page for TMM (linked below). Would it make sense that this step be added?
https://help.fieldsystems.trimble.com/trimble-mobile-manager/get-started.htm
Edit: Does Step 2 apply to all environments (Android, iOS)?
Edit: Step 2 makes sense...we are waiting for the GNSS to establish a position.
Thanks for your help, Zach.
Paul Lohr
Sent: 06-14-2025 11:43
Subject: constant disconnection from field maps
Paul, nope. This was intended for this thread. Field maps will invoke TMM. Therefore, you should never explicitly open TMM in this process. It has been this way for years. In the next release of field maps, you'll be able to open both and will be connected in both. That will come sometime in August. That being said, you could technically open TMM, but you would not want to connect to the receiver.
Zach Edwards
Sent: 06-14-2025 11:34
Have you tried uninstalling and reinstalling Field Maps? You'll have the pleasure of having to recreate your Location Profiles. ;)
We had this same problem a while back.
@Zach Edwards - maybe your response was intended for a different thread? Opening and closing TMM should not cause Field Maps to not store the authentication token.
Paul Lohr
