This seems like an awful lot of extra work and workarounds for what should be a fairly straightforward process. I'm not sure why you would use Google drive, WorksManager, and TCC simultaneously, but I would mention that Google drive is notorious for not carrying over the date timestamps for files and folders, which can sometimes lead to corrupted files. Also, when you copy files to TCC or Google drive, are you copying the entire SCS900 folder, the project folder, or just the individual design folders? I would strongly advocate against copying over anything that includes an XML file (all sites, or site) into TCC, especially if it came from an emulator.
Before our organization switched over to only using Worksmanager, my previous workflow for TCC exports was as follows:
- Start a new job on data collector, import CSV control from USB, and calibrate site if needed.
- Export .DC file from collector into TBC where I have my designs created.
- Use the job site manager within TBC to create a site, create designs, assign controllers and machines, and export designs locally.
- Export local SCS900 job folder and machine control data folders into their respective folders within TCC explorer.
- Perform a TCC sync on controllers and machines to receive all files for the project.
This served us well for nearly a decade, and there was never any need for an additional third party file host.
I would definitely recommend giving Worksmanager another shot. Yes, it has it's quirks, but when set up properly it does a great job of exporting designs directly out of TBC and out into field. We still use TeamViewer on all of our collectors, and still use TCC explorer for some things. But, I've found WorksManager to be the easiest way to manage our fleet of nearly 150 devices, despite the issues it may have.
Hopefully they help you get it sorted out. Good luck!
Brandon Tobias
