Dear Tom,
just like my collegue, I would suggest a training with your local distribution partner for more detaill.
To "merge" fence and photographs you would have to edit the template, the iFeature "fence" to be more exact, and add the attribute of a photograph to it.
(This would allow you to take one photo associated per iFeature)
The other option would be to work with multible active iFeatures at the same time, so you could collect the fence as you go and whenever you feel the need to take a photo, you activate the second iFeature for the point to collect a photo there as well.
As mentioned I would suggest a training with your local distribution partner for a more detailled workflow.
Of course you can also find information in our "Help" on How to modify an iFeature template.
Kind regards
Penmap support
Patrik Stahlhut
Sent: 06-06-2022 22:55
Subject: DA2 - adding a photograph as I record a datum
Hi Patrik
I replied to this email of yours a few days ago but I hadn't heard back from you yet
I still don't know how to merge the two capabilities - photographs and fence line
if I use the iFeature, topo, fence - then I can proceed to collect node/points and a line is automatically drawn (as you described) but from time to time, on one of those node/points I want to add a photograph that I can refer to later to draw my attention to some particular thing
I cannot see, following what you have instructed how I can do that – on-the-fly. Only by going back into iFeature ....
As I said, when I was introduced to this by the gentleman using an iPhone he was able to do both at once. Why can't I?
Your help ASAP would be greatly appreciated - had to cancel my first survey that I had booked into because I did not know how to achieve this
Tom Gardiner
FULCRUM Ltd
824 Old North Road
Waimauku 0882
Auckland
E: thomas@fulcrumltd.com
M: +64 275–90–20–90
P:+64 9–411–9004
F: +64 9–411–9024
Sent: 5/31/2022 5:33:00 AM
Subject: RE: DA2 - adding a photograph as I record a datum
Hi Tom,
when creating a project use the template "survey exmple" to have a "Foto" iFeature.
In the project, select an iFeature on the top right.
Choose Foto
You can now either measure a node/point to associate it with the selected iFeature directly via the GNSS button, or use the Snap node function to associate it with an existing node/point.
After you associated the node/point with the mentioned iFeature you will be able to take a picture via the camera button.
Kind regards
Penmap support
Patrik Stahlhut
Sent: 05-31-2022 01:55
Hi there Patrik
Thank you for your reply. Apologise for my chosen words. Yes I meant when I in the field and recording Heights and locations
I want to add a photo on key occasions
The person that initially introduced me to the DA2 was using an iPhone, which uses different software. So I don't know how to do it myself now.
So from what you've said I need to use a particular feature in order to add a photo...?
Can you explain that further please
