Hi
@Matt BrazierYou can use pretty much ANY app from the play store with Catalyst by connecting the DA2 in TMM and enabling mock location sharing.
If you leave this all connected in TMM then open your 3rd party app it should just use the GNSS position feed shared via TMM.
The help section
Location sharing with other apps gives more details
Otherwise is all you are looking for is a lat/lon/hae or MSL you might want to take a look at the
UAV Ground Control app - which is designed to do this for UAV ground control applications.
This will only output in lat/lon but you can setup a local geoid in TMM via the
GNSS configuration page. The deliverable is a simple csv you can share however you want from the device
Tom Harrison
